When using the feeder, it scans only one page. Thereafter, it keeps ejecting all papers. I am using paperport 12 to scan.
SOURCE: i have a brother mfc-7420
First install everything, than go to my computer at the bottom u will have Scanners and Camera, click on Brother MFC-7420 USB
Than if the window pop ups than click on Microsoft Scanner and Camera Wizard
Now u will have new Window "Scanner and Camera Wizard" click Next
On next page u will see Choose Scanning Preferences in there u will find "Paper Source"
click on the Scroll down option and pick "DOCUMENT FEEDER" and Click next
than hopefully u know wat to do pick the name fro scans that u going to make pick the folder to place it in and it will start scanning by it self and will send i to ur computer.
And put ur Scan paper with the side that u wanna scan FACE UP in the FAX tray which is on the Top or all in one Printer
SOURCE: OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
SOURCE: Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
