Whenever I play music and slide the phone down to use the multimedia key on the top of the phone , the screen won't rotate to Landscape mode.. and those keys are not lighted but the good thing ther is, it is still functioning... and that's also the same on watching videos or viewing pictures.. but the slide tone is still working on both slide up and close slide.. but it 's different with sliding it down.. I hope fixya team could help me with this matter...
your cellphone is fine. Its the strip which needs to be replaced. actually the strip connects the LCD and the navigation keys. U might have noticed sometimes your navigation keys also don't work. get your strip replaced n your cellphone will be fine again. slide up the phone and you will see 2 screws at the top. get these screws removed and replace the strip and also do change these screws after the repairing.
if the sound works when you put it on speakerphone, you may just need to repalce speaker. if it does not work on speaker you may have a more complicated problem. You can get a free repair diagnosis and estimate from www.fixphonenow.com cell phone repair services.
HELP - Nokia N96 Music Player Problem Well basically this is the problem , I got my brand new Nokia N96 two weeks ago. At first when I added the music, and I did the Refresh Library , it worked perfectly fine. But then after a few days, I added a few songs, but when I did Refresh Library, it didn't find any music
So I tried lots of different suggestions but I couldn't fix it so I decided to reformat my phone. After that when , I added music it worked again. But yesterday I added 5 new songs and again the music player didn't find the songs
Please people of Dotsis, I truly believe that one of you can solve this problem or give me any suggestion as I'm really worried about this problem...
In some of these instances, the only thing that you have to do is go to the Multimedia Message, and select Options (should be your left selection key). Then scroll down until you get to Objects, and select it. You should then see at least one object on your screen that has a musical note symbol. Open that item and listen to see if that is the correct ringtone. If not, go back one screen and look for another musical note symbol and select, then open. If you have found the ringtone, then just press the stop button (right selection key) so that the ringtone does not continue to play. Then, select Options, and you should see the Save option. Just select Save, and your phone will ask what folder you would like to save it to...
