I need help with dividing in square rooting. for instance when i do the square root of 32-64 divided -.5, i'm supposed to get 8 but i don't i get some random big number. I tried putting brackets but that doesn't work either.
SOURCE: Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
SOURCE: Trying to find standard deviation on the calculator
I took statistics last semester and I don't really remember how, but after you enter your data, you press SHIFT, then STAT (on the 1 key), then I think it's under 5 (VAR), and maybe Xon-1? Eh, funny how long you remember this stuff for....
SOURCE: square root of 0.5
Hello
If you want a number in decimal form all you have to do is press [S<-->D].
Hope it helps
SOURCE: I want to find the square root of a number and the
if it is a perfct square root then u will get a integer part.....if its not a perfect square root than obviously u will get decimal part........ u just check ur calculater in which mode it is......exit the radian and do it
SOURCE: how can I get the square root of a number that a
To calculate the square root.
Press the square root key, enter a positive number, close the right parenthesis (may be omitted) and press [=].
