Since the tv wouldn't come on, I pulled the power cable. When I plugged it back in, the tv clicked as if turning on. A moment later it clicked as if turning off. I then hit the power button. The tv clicked on, but didn't come on. Instead the power indicator flashes 4 times repeatedly. I then held the power button in for about 10 seconds. After this, the power indicator flashes 10 times repeatedly. Pulling the power cable takes you back to the beginning (blinking 4 times after reapplying power, waiting, then hitting the power button). There are three main cards inside this set. The power supply card, one labeled "TNPA5081", and the other "TNPA5082". Any ideas?
SOURCE: TV won't turn on.
hi i had the same problem,
did you check the fuse if it looks burnt out you can get a new one from a b&q or a hardware store
hope it helped
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
SOURCE: 50 inch Plasma panasonic TH-50PZ80U.
if you have a warranty let them check it out before opening the panels, it may void it.... may be an internal power short.
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
