I can't get my printer to pick up the paper in the paper tray and I have tried roughing up the rollers with an emry board and cleaned the rollers with alcohol but nothing seems to help. Should I just throw it away or how can I fix it?
SOURCE: Printer is leaving black ink marks all over paper.
Running cardstock lightly misted with water or dilute cleaning solution through several times can help. Use either the feed button or print using a program that allows you to print blank pages.
SOURCE: HP Laserjet 2100 not picking up paper from main tray
You could try simply cleaning the feed roller but it desirves more than that from the sounds of your relationship
The fed rollers are probally worn and need replacement,as you have had it for a long time and it has treated you well why not do the machine a favour and have a maintence kit fitted.
link to kit
link to just paper path kit can do yourself
instruction on installing
SOURCE: Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
SOURCE: Paper jammed in printer - need to remove paper tray
This works from HP help link in error message:
Turn off the
HP All-in-One.
Press in the tab on the rear
door to release the door. Remove the door by pulling it away from the
HP All-in-One.
Caution Trying to clear a paper jam from the
front of the HP All-in-One can damage the print mechanism. Always access and
clear paper jams through the rear door.
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
