Need code to work my tv with my TiVo remote
SOURCE: i need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
SOURCE: remote code
Hello steeler,
I am David thank you for choosing FixYa.com for your answer.
I went to the comcast site and found the numers you have there is another way to try also here it is
Searching for a code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
Example: You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
I hope this helps you with your tv Thank you again for using FixYa.com
feel free to rate me on my answer thank you again.
SOURCE: Need a code for Hitachi Ultravision TV
hold power and tv button same time
until power buttton stays on then
slowly hit power button until tv turns off then hit stop button and tv will work with remote
