SOURCE: MSI Socket A MS-6367 - motherboard - micro ATX - nForce 420-D drivers
give me *********** bord model number.
SOURCE: msi sli with evga 7900 gtx video card,doesnt post or turn monitor
The video card is not compatable. Also check your ram first to make sure it is plugged in all the way, and the rest of your hardware.
SOURCE: it does not work.
I recommend this board here, it is completely compatible with what you have now. It is a bit smaller than your board physically, but will definitely fit in the same case you currently have and will work with your components. Before you go to the link please make sure you click YES below my answer here to indicate it was helpful to you, it would mean a great deal to me if you could do so. Thank you so much, here is the link:
http://www.amazon.com/gp/product/B003CBXV6O?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B003CBXV6O
Testimonial: "this is the only web site I have found thusfar that has given me an answer to my question. I will investigate the responce and see if the recommendal"
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
hope this helps
