IT DID THIS ONCE BEFORE BUT IT CAME BACK ON THIS TIME IT HAS BEEN OUT FOR ABOUT TWO DAYS.
Hi Cecil Threatt,
I do hope this has been resolved by now, but if not I would be happy to provide assistance. The receiver may need to be replaced if it's not powering on. To help verify where the problem is, make sure the receiver is plugged directly into the wall outlet. If it already is, then if possible try another outlet.
If the problem continues we can look into a replacement. You can send me an email at [email protected] and I can help you further!
Tommy Faust
DISH Social Media Representative
SOURCE: Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
SOURCE: I want to connect dvd
Hey! This is Becki Barned, with Dish Network customer service!!! You may have already gotten this taken care of, but either way, here are some steps if you still need some help! How I imagine you have this set up, is that you have RCA cables going from the receiver to the main tv. In this case, you will want to take the RCA cables from the receiver to the DVD recorder to a port that says IN. Then you will want to have either coax or RCA going from the DVD from a port that says OUT to the tv. If you use coax, the tv needs to be on channel 3/4, and the DVD on an input. If you use RCAs, the tv will also need to be on an input, such as video 1 or 2. Good luck! Blog back if any troubles!! :) Happy troubleshooting!!!!
