Frigidaire washer model GLTR1670AS1 I've tried all the cycles. Lights go through the cycles but the washer will not drain or spin. It agitates but that's about all.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
http://www.applianceaid.com/frigwestwash...
check out this link for more help.
thanks
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Wanted to check if drain is plugged, but can't figure out how to get the bottom door off to expose drain and motor
agitates but won`t spin or drain
going into a spin cycle the machine stopped running, i have an error code e5e and a broken shock absorber
