Everythnig elas is working - have oiled the machine as per manual but there is absolutely no way I can get the black wheel that changes the type of stich to turn/move. Please help!
SOURCE: I inherited a Necchi 537FA machine and am not sure which button
does anyb ody have a manual i can download
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
SOURCE: I have a Necchi 537FA sewing machine. It sill sew
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
SOURCE: I have an older Necchi 544. It will pick up the
Could the needle be in backwards?
Flat shank to the back. Is the needle fully up into the housing?
If these check out okay then the timing could be off. If it hasn't been serviced in last 2years then it might be time for one.
Thx Debbi - I also came to this conclusion this morning. Although I;ve oiled/ DW40;d all the parts I can - even took the side off that 'houses' the dial and oiled all parts, but dial still won't move and machine will not sew either. So will need to find someone locally who can look at it for me. L
