Bosch washer Classixx 1200. It starts off fine, fills, washes, and then when it comes to spin, water leaks out from underneath. It's quite a bit of water, but not a load's worth.
SOURCE: EWC177 Eurotech front loading washer.
Hi.
If the motor runs and machine drains regularly then the problem is usually the pressure switch.
Before replacing pressure switch test also the door lock. To test it in full a technician must jump its contacts.
I've pulled it out from the wall, and there doesn't seem to be any water behind it. We recently started using powder soap instead of liquid. I wonder if that's led to a blocked drain. There are eight in the family, so the machine is well used.
The solutions were great. We fixed the machine, but I don't see where to rate the answer. If I could rate the solution, it would be a resounding yes.
