I need a new timer. on my old unit wires come thru back of box. i see on the new ones 2 punch outs at bottom of box for wires. is there also a punch for wiring thru the back of box !
SOURCE: I have 4 wires on wall switch red, white, black,
It appears that you should have an ej353 instead of the ej351c. If the switch that you are removing has a red, white, black and copper wire on it, it sounds like you are replacing a 3 way switch. The model ej351c switch is made for a single pole switch and not a three way switch. You can find additional information on how to wire your switch at: http://ec-images.acehardwareoutlet.com/shared/productmanuals/30088manual.pdf
SOURCE: replacing an old timer with a new gm40.
Here is the instructions for your unit:
Intermatic GM40
Go to page #4 for wiring instructions on 120v dual loads.
Hope this helps and please rate this!
SOURCE: I just installed a new T104M and still have no
Looks like you wired everything up OK on the timer. Using a Multimeter with an AC range of more than 240V, or an AC tester, check for voltage at terminals 3&4. Make sure the clock is set to the on position. You should get a reading. Go down the line to the pump, and check voltage on the pump to make sure there's power from the timer to the pump. If you have voltage from timer to pump, sounds like the pump is not working. If the pump motor has a starting capacitor, it may be that. They are replaceable.
Please be careful with that 240 voltage.
SOURCE: i have an old intermatic (1983) freeze guard that
There is not a set color code when it comes to that stuff. If the timer is still connected and there is power to it, turn the manual ON/OFF lever inside the timer to the OFF position. Using a volt meter set to at least 240 volts, test the wires. The set of wires that are still hot are the LINE wires.
If the timer has altready been removed, you'll have to _carefully_ separate all the wires so that they aren't touching anything and re-energize the circuit from the breaker. Then test the wires. The 2 wires that are hot after re-energizing the circuit will be the LINE wires.
SOURCE: the t104 comes new in
277V instructions say:
Move small white motor wires to terminals A and 1
Connect 277 Neutral wire to terminal A
Connect 277 Hot to terminal 1
See illustration:
http://waterheatertimer.org/images/T-104-control-120V-Load-277-400.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
