Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
Beth Narayanan Posted on Apr 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
Debbi's Sewing Machine Repair
Level 3:
  • Singer Master 7,365 Answers
  • Posted on Apr 12, 2012
Singer Master
Level 3:
Answers
7365
Questions
Helped
1741628
Points
19451
Try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
3 Related Answers
  • 7365 Answers
  • Posted on Sep 14, 2011
SOURCE: it is a singer quantum futura ce 200 sewing and
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Anonymous
  • Posted on Dec 28, 2008
SOURCE: while sewing on singer quantum
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
Anonymous
  • Posted on Mar 15, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
How to skip stitches on a embroidery design
Use the Needle Up/Down button to skip Forward thru a Design.
Singer CE-200
since it is a embroidery machine I would suggest the technican
to be on the safe side
Which format should I use for my Singer futura CE-200 when I download embroidery deisgns
The Futura should run any format program but its dedicated program type is XXX so if you have that option I would use that one.
What embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
My Singer Embroidery machine works wonderfully on embroidery, but...when strait stitching or design stitching...constant error. Thought it was the tension, so I've tried every setting. Still beeps and get...
HI,
Did you make sure that you raised the feed dogs? There is a sliding button on the front that you have to move sideways to let the feedogs come up. If not the fabric is not being move right and that may be the reason of the wrong stitching.
Also, are you oiling your machine appropriate?
New Singer Futura machine stops & tries to revert to overlock.
Sorry to say but it sounds to me that you need to take your machine in to be checked.
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
3answers
Other brands of Software
You can only use the futura software, autopunch, hyperfont and cross stitch
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
