Forgot password I can't remeber the password to my acer aspire 5315 laptop. I tried to start it in safe mode, but wen i click on safe mode it says loading windows files and then goes on to the main log in page, and keeps asking me for the password. I went onto repair windows after pressing f8 on startup and when i tried to log in as guest it said it has been disabled so i tried administrator and it said the same again. please help
I have the same problem but do not have the know how to open in safe mode but did try the F8 key but that did nothing but bring up the same "Enter Current Password" Can someone help me?I have the same problem but do not have the know how to open in safe mode but did try the F8 key but that did nothing but bring up the same "Enter Current Password" Can someone help me?
AnonymousNov 24, 2008
where do i find the password recovery software?where do i find the password recovery software?
You can't post conmments that contain an email address.
Go to Orphcrakcer.com You need download a password recovery tool, but youll need to burn it to a Cd then put it in the CD drive>turn on the laptop> and let the laptop boot from the cd. Follow the instructions on the screen and in a matter of 3 mins you will have recovered your pswd
Hi junior 707
Try this solution to your problem.
Start your computer 1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer) This will start the computer in Safe Mode. 2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode. 3. Once you are in the Safe mode Click "Administrator" on the Windows login screen. Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank. 4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password. 5. Restart laptop and login into the account you just created using your new password. Please take time to rate me thumbs up
Yes, you get the way. By relying on this password recovery software, you can reset Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit.
First reboot Windows XP in safe mode by re-starting the computer and pressing F8 repeatedly as the computer starts up.
Then (in safe mode) click Start and then click Run. In the open box type "control userpasswords2" (without the quotes, of course)
You will now have access to all the user accounts, including the administrators account and will be able to reset the lost password.
Just click the administrators user account (or the target user's account), and then click Reset Password. You will need to add a new password in the New password and the Confirm new password boxes, and confirm by clicking OK.
Here is what you need to do
1. Power on the machine 2. At the white ACER BIOS screen, hold the “Alt” key and press the “F10” key simultaneously to start Acer eRecovery 3. Once eRecovery has loaded, you can cancel the process and now your laptop should boot normally or you can click “Restore to Factory Default Settings” 4. Click “OK” to continue . 5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes). 6. Once eRecovery has run, press “OK” to reboot unit
Try starting in safe mode (press f8 on start up) once in safe mode use system restore to restore your operating system to a earlier point.
For XP
Start - programs - accessories - system tools - system restore.
For Vista
Start - all programs - maintenance - backup and restore center
