Hello i have a problem with my Archos 504 it will not pass the start up screen, when i turn it on it stays on the green start up screen, i have tried all of the solutions suggested here and on other websites such as pressing the reset button for 10 or 20 seconds, pressing the lcd/ tv button slightly before pressing the power up button to get it to boot into the recovery mode but none of these solutions have worked.
I am close to binning the thing but am reluctant to as i have a lot of stuff on it that i do not want to loose.
Thanks for your time lerniefalls
SOURCE: can't get out of recovery code 2 on archos 504
Try my suggestion to "recovery code 4" error. It should work, too.
SOURCE: Archos 504 RESET button
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
SOURCE: recovery code 4 on archos 504
Hemansd
Thanks for your advice my Archos decided to die on me , not as bad as a ipod :) thanks for your tips did the job nicely
SOURCE: Archos screen only
solution found!!!!!!!!!!!!!!!!!!!!!!!!!!! thank you so much for the support of the Archos team. here is what i did to repair my 504
if your "reset" button doesn't help at all, this is what you'll do.
If you power on the unit by pressing and holding the TV/LCD button and power
button simultaneously the unit will boot into a recovery screen. Once in this
screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of
the unit:
http://update.archos.com/4/a504/a504_r1.6.53/a504.aos
before i found this solution, i've already given up on my 504, but now it's back!!!! REBIRTH!!!
thanks once again to Tony H from Archos Technical Support
