You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
hi, u can connect the computer to ur projector for that u need Signal interface cable. its number is SIC-HS30. u can connect one end to the vga out of pc and the other end to pj Multi input of ur projector. ok
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3. 1st thing to check - is the cover properly/completely closed - this can stop the projector from working. Connect the power and set the projector to standby mode. Press these buttons on the remote control in this order, for less than 5 seconds each. Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
