Check your firewall and port settings.
Try to disable firewall on your computer.
Do you have a router on your network? If so, you need to open ports on your router.
It's the microphone.
Locate the Test Call in your Contact List and follow the instructions. It'll call up Skype and after the prompt your voice is recorded then played back to you.
HI THERE IS LOOSE CONNECTION TO SPEAKER
I think speaker needs to be replaced .
Reciving hearing speaker is damaged you need to replace it, via service center
The volume must be low in the settings, try adjusting the volume
