SOURCE: TV will not come on
I had the same problem. Turns out that my color wheel motor went dead. Unfortunately RCA stopped making the part. The good news is that I purchased the replacement plan for the TV, so I ended up buying a Samsung. Best thing I did was the replacement plan!
In addition to the color wheel, the bulb went out twice. Warranty paid for 100% of it. Good thing, the bulbs were $400 a pop.
SOURCE: RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
SOURCE: picture flashes off but still have sound
You may want to change the lamp. It may be on the edge of failing totally.
Hope this helps,
Skyassoc
SOURCE: power light flashes 3 times
You can get the CP150, CP120 and Cp114 repair kit at the following link which will usually repair that issue. Its at the bottom of the page under the RCA repair kits. The kit contains the capacitors and detailed instructions how to do the repair. www.tvrepairworld.com
