I went into f10 setup and hit enter to get out of the screen however i change the settings. how do i reset the settings
SOURCE: Hp business pc/912: error while booting/ reset case disabled
Go into the BIOS and disable the error message. You will need to look around in the BIOS to find the exact location of the enable/disable setting for case intrusion.
during the boot sequence hit delete several time and the cmos setting will pop open, make sure your drive is recognized.
set to auto detect and see if it finds it.
make sure your drive jumpers are set to master or slave. for the new drive master.if it's a single drive you usually remove the jumper connector.
make sure your master drive is at the end of the ribbon cable
change your boot sequence to cd cd cd and boot to the cd
then your windows cd will boot and you go through formatting and partitioning
once your done you will have to reset the boot sequence in the bios to boot to the hard disk.
Hope this helps good luck
SOURCE: Reset BIOS on HP Pavilion a750w
Fastest way to reset BIOS is to remove the CMOS battery (looks like a large watch battery on Motherboard) for 30 minutes. After you replace the battery, the BIOS should reset to default. If further problems arise involving the BIOS, it's possible the CMOS battery is bad.
SOURCE: HP505N. Kids messed with computer and it shut
pres f 9 to choice boot menu. Or go F 10>go bios for set boot piority>and F 10> yes enter.if not work please re install xp .and create partion again ,because your kids can be delete the partion file (ntldr/boot.ini).
Restart you computer during the boot process you will see on the screen to press a certain key to enter setup usually the F2 or the Delete key
Press and hold that key during the boot up process to enter BIOS the navigate to advanced bios features using the arrows keys press enter change your first boot device to cd press escape then press F10 to save to cmos to restart
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
