The safe has a seven digit number by the key lock. Is it possible to purchase replacement keys?
Yes. That seven digit number is the key code. A locksmith who is well stocked should be able to cut new ones from just the number.
Otherwise write to the manufacturer of the safe or the lock and provide the number and they should send the new keys.
in either case, there will be a nominal fee.
SOURCE: Nutool SF10 electronic digital safe
Open the safe door and press the s key press the I key twice then press the red button on the inside of door near the hinges. you will hear 2 long beeps. press the s key and then the red button and you will hear a beep enter your combination up to 12 numbers then press the E key your combination is now set. Best of luck
SOURCE: We have a Nutool SF10 electronic digital safe, the
I used my wife's hairdryer and heated the outside for a few minutes so that the heat could get to the batteries. Left it for a few minutes and tried to open it once again and Bingo.. it opened..
have new batteries and told the wife not to forget next time..
