You might have the problem, either with the os or with the RAM...If it is the os problem so u should go for a new one...(Means Re-install)And if, It is the problem with the RAM so u should put out the RAM once after that clean the golden corners and re-insert it.....First go for the second (RAM out then in),.,,,If the problem isn't corrected with both methods so u will have to replace the old RAM with a new RAM.....Because Mainly the RAM is responsible for the display in a computer...
