Question about Cisco ASA 5510 Firewall
Activation key how to get the activation key for asa 5510? urgent please
  • hzhoor Nov 12, 2008
    login to cisco site
    run show vertion in your asa
    send them this key & they will send you activation key by the email within less than an hour
    Problem Solver:
  • 16 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step 1
Obtain the serial number for your security appliance by entering the following command:
hostname# show activation-key
Step 2
Access one of the following URLs.
Use the following website if you are a registered user of Cisco.com:
http://www.cisco.com/go/license
Use the following website if you are not a registered user of Cisco.com:
http://www.cisco.com/go/license/public
Step 3
Enter the following information, when prompted:
Product Authorization Key (if you have multiple keys, enter one of the keys first. You have to enter
each key as a separate process.)
The serial number of your security appliance
Your email address
An activation key is automatically generated and sent to the email address that you provide. This key
includes all features you have registered so far for permanent licenses. For VPN Flex licenses, each
license has a separate activation key.
Step 4
If you have additional Product Authorization Keys, repeat Step 3 for each Product Authorization Key.
After you enter all of the Product Authorization Keys, the final activation key provided includes all of
the permanent features you registered
Posted on Feb 12, 2009
    New Friend:
What is the activation key for Cisco ASA 5505 firewall and I have the serial number jmx15274126 for ASA 5505
Posted on Mar 30, 2012
SOURCE:
How can i get into ASA 5510 after lost password
Its simple, you have reboot with console connect, get into to ROM mode and change configuration registry so it will not load the saved configuration. Please refer Resetting the passwords on Cisco ASA 5510 Binary Royale Ltd for the step by step process
Mar 21, 2013 | Cisco ASA 5510 Firewall
Does anyone have a activation code/key for pc utility kit? Its urgent please
I'm sorry but this is not a warez site...We can't give out activation keys or access codes.
Sep 04, 2012 | HP Computers & Internet
I have cisco asa 5510 firewall and i have dialup internet connection i want my asa 5510 between my LAN and my dial up internet
Your best bet is to place the ASA into 'transparent' mode, and letting the traffic pass through it and be inspected on the way through.
To do this you need to first do the following command:
firewall transparent
Once in transparent mode, the firewall will no longer look like a hop in the packets journey, and you can set rules to allow/disallow traffic using access lists on the inside and outside interfaces, plus you can perform packet inspections using policy-map and inspects.
Hope that helps!
Feb 12, 2010 | Cisco ASA 5510 Firewall
Block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
Feb 10, 2010 | Cisco ASA 5510 Firewall
New cisco asa 5510 setup
connect your laptop to the asa5510 using a cross over cable
Oct 07, 2009 | Cisco ASA 5510 Firewall
ACTIVATION KEY FOR KASPERSKY
You need to contact Kaspersky. The activation key is calculated using your name
Oct 04, 2009 | Nokia 6600
Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
Apr 18, 2009 | Cisco ASA 5510 Firewall
Failover best option required..
You can only do active/active if you're using multiple contexts. Active/active can give you some extra performance for your $ since you can pass traffic through both ASAs. Compare this to active/standby where the standby unit passes no traffic.
If you're pushing the 5510's to 80% capacity each in active/active mode, then you have one fail, now the one single ASA is oversubscribed. The oversubscription could cause connectivity issues that defeat the purpose of failover in the first place.
In the spirit of reliability go with active/standby. Seeing that you have two active core switches that would be pushing all of their traffic through a single 5510 in this case....it may be too much active/active may be the better solution.
Mar 31, 2009 | Cisco ASA 5510 Firewall
Key for activation of windows vista business
i can not activt my windows vista black edition.please send me activation key in my mail.my mail id is...
smirdey@gmail.com...
please it"s urgent
Jul 04, 2008 | Microsoft Windows Vista Ultimate Edition
Cisco ASA 5510 Firewall Logo
4,306 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
