Make sure you have media player 11 If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this. Download recovery tool off creative's website. go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them Also told Microsoft hotfix causes this problem try uninstalling the last hotfix If that doesn't fix it trythe USB cable
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen. In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
What error-messages do you get?
From what web-site are you trying to download?
What happens?
What does not happen?
Using Mac OS? Windows XP? Windows Vista? Windows 7?
You will definately need to be more specific.
Check cables make sure you are plugged in.
Reboot (restart) computer.
Power cycle Modem and Router if applicable. (unplug power 30 seconds then plug in Modem when online then replug router wait for to be online, then start computer).
Hi. You normally do not need a driver for MP3 players with XP. You should just be able to plug it in to the USB port, then wait for it to find the new hardware, then it will show as a new drive in 'My computer'
fredwards - plug mp3 player into computer, Double-click My Computer, and right-click icon of RCA, select FAT32 if you are running Windows XP or Vista (if you have a MAC, these instructions will not work)
Try this: disconnect the player from the computer, turn it off,hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
This player works only with Windows XP/SP1 or below. Here is an exact quote from the company: If you have WindowsXP SP2, we recommend that you go back to Windows XP SP1 before Microsoft solves the problem.
If you are using Windows 95, the player is not supported. If you are using Windows 2000 or XP, it will show the player as MTP player. If the MTP is not shown on My Computer, install the player as removable disk (use Device Manger, find the device connected, right-click on the player icon, and click Update Driver).
