After a power outage my rvm1635sk01 would not power up. the wall outlet is energized at 118.3v. the display is blank and the controls are unresponsive
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller. This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on. If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
