My Panasonic DP-C263 machine has the foll error code on the screen E05-73 how can I fix it myself and what is wrong with my machine?
E5-73 is a HDD Abnormal Operation. First try turning the system off, counting to 30 and turning it back on. If it persists you want to check the HDD connections. May be a failed HDD. Panasonics exact answer is:
1. HDD connector is disconnected.
2. SC connector is disconnected.
3. HDD is defective.
4. SC PCB is defective.
SOURCE: Panasonic Workio DP-1820 error code E4-01
error code E4-01 means you have a fuser warm-up temperature problem. try a lbp fuser reset in service mode. i dont know what you password is so i cant tell you how to get there but good luck
SOURCE: panasonic DP 3530 printer keeps saying Machine error E03-40
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
SOURCE: Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
