I have an E9 that I'm reassembling after taking apart and cleaning the coffee spout that was completely clogged with coffee residue. The only part I'm having trouble with is that the adjustable spout. Upon an attempt to reassemble, the spout won't stay in the up position. I think it's due to me not remembering how to position the two small metal strips that provide resistance. Any ideas how to postion the two meta strips?
SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following:
1) take of the warmer plate on the top - 2 storz screws but an allen key works as well
2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess
3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front
4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly.
5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely.
6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free
7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel.
8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece.
9) You will now see the plugged spouts.
It goes back together really easily.
SOURCE: Both spouts seem clogged
If you remove the front spout assembly there is a very fine screen located just above the spout outlets. These screens and spouts can become plugged. This should be removed and cleaned. If this does not help there may be other issues related to low water pressure. This is usually indicated by weak coffee and excessive water in the tray though.
Mike
SOURCE: Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
SOURCE: Have reassembled the Brewing unit - am now getting Malfunction 8
oh dear that is too long without a coffee ;-( I was wondering if you could share your knowledge on how to dismantle the Jura coffee machine, i have a E85 and i need to remove old coffee sludge that is causing my problems. do i remove the back of machine?
