My printer does not print but all diagnostics say there is no problem. how do i check my ink levels?
SOURCE: Scan using the HP OfficeJet 4215 Printer
The problem is with Windows Vista...it does not recognize the scan button when you touch it on the scanner. There are two ways around this:
Go to Programs / Windows Fax & Scan / Click new scan / click file and then click scan
OR
Go to Accessories / Paint / Cick File /click from scanner or camera / click scan
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
SOURCE: How to check ink level for a hp 1210 printer /vista
SOURCE: how do I check the ink level of my HP Officejet 6300 series?
only wy to check levels is to install the software that is part of the printer it will give you ink levels as they go down
