My Maytag MAH2400AWW washer won't drain -- it makes a loud buzzing noise. Before it started doing this, it showed "nd" on the display once.
Is the pump dead or is it just clogged? Where is the pump and how do I get to it? There's still water in the machine.
Pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. Please get back to me if you have any other questions.
Kevin
I'm still having trouble getting to the pump. Removing the 3 screws at the bottom allows me to lift the white front panel (where the door is) up a bit but it's still somehow hinged at the top.
Is there no way to remove the silver panel?
Did you mean I need to tilt the machine and access the pump from UNDER the washer? This could be difficult because there's a dryer stacked on top of it...
