The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
yes you should get some kind of power indicated that power is on the machine i would first check the circuit breaker and then assure that you have power coming out of the outlet after which you could then use a multimeter to folow where you do have power going to sometimes it could also be a bad switch on the unit itself but first assure where you do have power going to and any further questions message me back Thanks Rick
It is most likely the switch. To be certain, hold the lower switch button on the front in with a small screwdriver and push the switch. BE SURE to push the button in first, and then the switch. If the motor doesn't start, you need a new switch assembly.
The front safety switch must be pushed in by either the hose or head (or manually), before the on/off switch will operate. The most common reason for no power is a bad cord. Second most common is worn carbons in the motor, and third is a bad switch.
Either the cord or the switch is bad. The cord is simple. Take the tab screw on the back of the machine off and the screw holing the cord cover off. Pop off the cord cover un-plug and remove then reverse steps to replace. If it is the switch that is better left to proffesionals so call your local vacuum shop.
it could be the switch they do fail. i would test the power do you or someone you know how to use a multimeter if so test the wires for power in the on and off position if it has power to both sides of the switch than it is for sure good if not its bad, if its good test and see if you have power to the motor if it does then the motor is bad if not test power to all items along the wire until you find the place where the power stops and that will be your bad part.
