I have 75K miles on it. Since last couple of weeks, I am hearing A cracking noise each time i start the van. I heard minutely and it comes from engine. Took to autozone, they said it could be valve in engine. COuld cost me $6-7K from dealer. Anyone had this problem and how did u resolve/ Would be of great help to know before i take to dealer. We all know how the dealers are a ripoff. Thanks for any suggestions.
Check this video out. Nissan 3 5L Timing Chain ticking
SOURCE: 2005 grand caravan-erg valve needs to be replace
had same problem 2005 Grand Caravan clean electrical connection to egr valve before replacing valve corrosion causes a low voltage to valve shows OBDII code P0404
SOURCE: 2002 Nissan Quest tuneup and stuff
you have a timing belt.i would replace.plug wires air filter plugs fuel filter distributor cap and coils.replace pvc valve replace all vacuum lines or hoses.replace timing belt.
SOURCE: 2004 Nissan Quest - Engine chatter/knocking
Ther e is a chance your injectors are leakin g down and there is excess fuel in the cylinders. Not a good thing. So, you fuel pressure and injectors need chkg. good luck
SOURCE: 2005 nissan murano sl, with rattling sound when accelerating
I recently experienced the same symptom with my '05 Murano and it was not a fuel problem. The dealer listed the cause as dry axle splines and replaced both front drive shaft assy's. Note that this was done as warranty with no cost incurred by me.
