Majesco Zumba Fitness (Kinect) for Xbox 360 Logo
Anonymous Posted on Apr 10, 2012
Won't let me edit player
Alot of the Main menu items (including edit player)are grayed out and won't work. I thought that maybe I needed to play first, so, I went to play but most of the menu items there were grayed out and wouldn't work (including tutorial). On the sign in page, it always declares me as a "guest", which I thought might be part of the problem, but, I don't see a way to fix it. I am incredibly frustrated...
  • Anonymous Apr 13, 2012
    I did sign in. I don't have xbox live, but I was under the impression that the game should work reguardless. However, I called Majesco customer support. They said that the problem is due to one of the updates for xbox (my husband has Live). So, bcz I don't have LIVE on my account, It wouldn't recognize me when I signed in.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
1061
Points
18
Try signing in.............
1helpful
How to re-enable inaccessible TV menu options?
Go to thru the main menu until you reach the menu item that says "Reset all".
2answers
Rear speakers do not work , also in set up menu they are grayed out.
hi there
when playing radio, the rear speakers do work because you have configured that. in your dvd player however, you may not have configured it yet.
Correctly insert the jacks at the back of the dvd player and at the same time, check the menu of your dvd player and check the audio settings. Under the audio settings of your dvd player menu, select the 5.1 or 6.1 audio profile.
hope this helps.
2answers
The battery is dead and won't recharge
Have you thought that maybe it's time to buy a new battery?
1helpful
Big gray spot on screen
Unfortunately, It's likely that your screen has been irreparably damaged. Probably, pressure was applied to the screen and ruined that part of it.
If you like to fix electronics, it may be possible to buy a non-working Sansa on eBay, open the case and replace the screen.
You can probably continue to use the player without fixing the gray spot. If it bothers you, the easiest solution would be to get another player....
My 2yr old whirlpool dishwasher model# DU1145XTPBA, ser# FU3026019, 2.7 amps, type# 5750-0 has stopped turning on. I never had any trouble out of it and now it won't turn on. I thought maybe a fuse...
It is possible the thermal fuse located in the control panel has blown.
See item 5 in this diagram. You could attempt to replace it.
make sure the power is disconnected when you are working on the dishwasher.
Hope this helps.
Both lights flashing and won't print. Help!
hi,
please visit the site
I have printed both from the CLI and the GUI; no difference. I thought maybe the paper ... http://www.openprinting.org/printer/Kyocera/Kyocera-FS-920 .... Also it seems the CD supplied drivers won't solve your problem. .... And NO WD-40 on plastics, better take silicone spray in a very light dose. ...
forums.scotsnewsletter.com > ... > Main > Bruno's All Things Linux - Cache
My Phillips GoGear Vibe won't go to the main menu. It freezes up on the ViBE sequence. I tried soft resetting and turning it back on but it didn't work!
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue
To update the firmware perform the below task:
  • Download the newest version of the Philips Device Manager:
  • www.usasupport.philips.com - change your country/language as needed
  • Enter in your exact model #
  • Click on the link for your exact model #
  • Click on the Software & Drivers section
  • Click on "Firmware Upgrade Software"
  • Install the new Device Manager
  • Open and run the "Update" tab
If you need any further help, please email us back so that we can continue to work on a solution.
I have a pixma 1500 and I need to print black and white prints. I am using edible paper and edible ink. Instead of black and white I am getting pinkish gray instead of gray. I was told before that I...
Apparently, when grayscale printing is selected, some color ink is still used which is why you are getting a pinkish gray color instead of just gray. Here are instructions for solely using the black ink tank.
Print using pigment black ink only (Windows)
Instructions to print using only the pigment black ink tank only. Occasionally you may need to print using black ink only. Using grayscale alone does not provide this option and the color inks will still be used. By following this procedure you may print using only the pigment black ink tank.
Note: Some color ink will still be used for print head maintenance.
Note: Image quality may be sacrificed when printing photographs.
Open the Properties / Preferences window for the printer.
For Windows 7
Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
For Windows Vista
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/ Me/98 (if applicable)
Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
Click on the Main tab.
Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
Top Majesco Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Majesco Video Game Console and Game Expert? Answer questions, earn points and help others
