If you have the beat generated, and merely want to save it, press Write Button once. Use the tempo up and down arrows to select the memory location and press the Write button again. it should store it.
If you are just looking for a different random shuffle, the metronome is hard coded and limited to what you can change on it.
If you did not get the owners manual, it is here:
http://media.rolandus.com/manuals/DB-60_OM.pdf
Heres how to restore your MPD24 factory defaults using the Vyzex software:
1. Plug in your MPD24 with USB cable, and then open the Vyzex software.
2. Click File > Open
3. Select Factory SET.SQS, and click open it.
4. You should now see BFD Lite and other details on the Vyzex MPD image.
5. As long as you're on the DATA tab, you should see a PUT SET button available. Press it to transfer the factory presets to your MPD24.
6. An overwrite warning will be displayed. Press YES to overwrite your damaged MPD24 presets with the factory presets.
You'll see a progress bar filling up for about 10 seconds, and then once it disappears, that's it!
You're all done - Enjoy!
