If the Samsung C3050 says invalid Sim means it locked to network ...you need to unlock it...You need to specify the network locked in spain...I have unlocked my SAMSUNG C3050 from Vodafone spain using the unlock code from the site Simpleunlocking.com/samsung-c3050/rs16wp9/ and got the free UNLOCKING instructions at here Mobileunlockguide.com and unlock it step by step.So you can unlock it and use woth any GSM Network Sim card.
SOURCE: Showing INVALID SIM
try *2767*3855# this will reset the software and unlock your phone to all network, but make sure you backup all of your photos etc before tou type this code in.....Chris
SOURCE: Already have numbers saved to
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu
Select Address Book (8)
Select Contact List (1)
Select the desired contact entry, stored in your phone's memory, using the navigation keys
Press the left soft key for Options
Select View (1)
Select one of the contact phone numbers, using the navigation keys
Select Copy (3)
Select SIM (2)
Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
SOURCE: Samsung G600 - phone asks for sim card but doesnt work when inser
when phones get wet they start to rust from the inside, unfourtunaly this is a long prosses and can take a few months but usually if the phone has got very wet they will not work propley again. they may work temperally but eventually it will probably be completly usless. in future if u wet a phone try drying it immediatly with a hairdryer, inside the battery bit too, this may help the water inside the phone not to cause rusting. sorry about your phone.
SOURCE: forgot sim lock for samsung D880
call the customer care and get ur puk number...!!!!now enter the puk number instead of the sim lock code.....actually when u enter wrong code for more than 5 times it ll automaticall ask u the puk number.,....in this tab enter ur puk value!
