So my dash lights dont work, the display that shows temperature how much gas u have doesnt work. Doesnt work as in doesnt light up. And the security light comes one and prevents car from starting? Does that mean that the ECM or BCM doesnt work? Cause fuel pump and filter have been changed. Also when i try to get codes it doesnt retrieve nothing doesnt even show thats its hooked up does that mean the computer is shot(dead), and is the reason to those thigs happening? PLEASE HELP! Or could it be the anti theft preventing anything from happening??
SOURCE: Emissions sensor fuel tank 2001 gmc jimmy
I don't think you have anything wrong, I just don't think you have completed the correct drive cycle yet. Some vehicles must be driven in a very specific way before all the monitors will set. Here is the drive cycle that Gm Recommends:
Do not leave the key in prior to the cold start or the heated oxygen sensor diagnostic may not run.
SOURCE: 2000 gmc jimmy wont start fuel pump comes on and cuts off...
the fuel pressure if leaking could cause this the regulator is located under the intake plenum but you should smell gas .if you dont then most likely the pump is bad ,the pump will come on for 2 seconds when the key is on then go off it will not stay on with just the key on only when you crank it will it .so have your fuel pressure checked with a gauge.
SOURCE: 2000 GMC Jimmy will not start
The oil presure switch does have some bearing on the problem but my suggestion is to change the coil. I had a the same problem with an astro van. I changed everything that you have described and it fixed the problem just for a little while and then all of a sudden did it again. I changed the coild and the cold start swithch and never had the problem again.
When you hook the pressure test guage to shrader valve on fuel rail what it reads is what the pressure is from pump, around 60 p.s.i. all you need to do is hook up the guage and turn on key, you do not have to turn engine over, and if pump is good it will shoot up to 58 or 60 right now.
SOURCE: 1994 cadillace anti theft system
I just had this same problem with a '96 . do you have a vats key in your '94? you need to bypass the VATS system. read some of the blogs on this site and it will tell you how to do it. I fixed mine with a $2 resistor from radio shack.
