It was working fine yesterday but today only the clock works. Neither of the two ovens work nor the internal lights. Could it be one of the elements or the thermostat needs replacing?
Thanks for your help
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Thanks parsonm for your response. In the end I had to call out an electrician and he said it was the clock. A new clock is well over £100 but he was somehow able to bypass the problem. Although I can no longer use the auto timer, everything else works and I can cook my diner!
Bought a Stoves double oven no plug attached any idea what amp needed
