Tv may turn on for a few minutes, sometimes an hour..but shuts off on its own with no correlation to remote use. PLEASE HELP
SOURCE: remote control codes
The only remote that works is the one 4 all. Call ONE 4 ALL for the right model number. They then can program the remote on the phone to operate the SVA tv. It worked for me until the set died this week. Guess why I am looking on this site.
SOURCE: My dad smashed our remote [Dont ask...] to our SVA
almmost all tv's have a manual power button. look around the perimeter of the tv, sides, etc.
SOURCE: sva tv model;HD4208Tiii-pop will work for 15 minute then turn off
We have identified a common problems with theses sets manufactured
by, SVA, Gateway, Viewsonic, Sampo and a few other brands. They all have
a Samsung power supply board (LJ44-00025A), which has cause these
units to lose power. There is a easy fix, replace the power board. But
you ask why should we? That's the right question. If these boards all
have the ability to fail with various parts and within various
displays.This has to be a defective part. As of now, there is no recall
on this part. Therefore, we are generating a list of customers, who own
these displays and are requesting a refund for previously purchased
parts or a replacement part at no cost to the customer. We are in the preliminary stages, so please be patient with our efforts.
If have identified your unit is salvage by an power issue an wish to purchase
the identified part (LJ44-00025A, we recommend you purchase from http://www.adc-ast.com/.
We cannot guarantee that any monies will be refunded by this claim.
Thanks
Shawn Moffett
Samsung Claims Administrator
If you are interested in participating in this claim, please email the requested below to [email protected]
<NAME>
<ADDRESS>
<PHONE>
<EMAIL>
<MODEL>
SOURCE: SVA PLASMA TV
I got this same tv from a guy in my area he would press the poewer botton on the tv and the standby light comes on and then turns off, so he gave me the tv for free i took the back panel off, and everytime i press the power botton the green light came on where the screen board is and went back off after i let the botton go i took the power board out took it to a repair shop to see if there was anything a wrong with it everything was good so i replaced the two fuses on the board and the one on the screen board, i had a feeling about the power switch so i jumped the wires on the switch purple to purple and green to green, I put it back together pluged it in the standby light came and stays on now, so i went out and got a universal remote for the sva at walmart for $15 programed it and pressto the tv works perfect so three fuses $3.60 two small pieces of wire and ele tape $0 my time 35 mins = one working plasma for $3.60 so when you have this problem like everyone else check the power botton switch, there cheap and check the fuses theres only three and if that dont work idk what to tell ya. and you do need a remote or tv wont work.
SOURCE: I have a Plasma, SVA 42
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
