SOURCE: channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
SOURCE: Lost channels 2 through 52
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
SOURCE: Stuck on channel 3
Set-up in menu = step thru each page = skip what does not
apply to you = get to auto-program....be sure signal is attached
to set first.........................T.
SOURCE: autoprogramming
On many televisions with built-in tuners, you have to tell the tuner whether it will be connected to cable or antenna, since the RF spectrum is different for these. Make sure you have cable selected (assuming you are connecting to the cable service) and then try the autoprogramming again.
