Question about Kenwood KVT-715DVD Car DVD Player
Kvt715 telling me i have a disconnected wire, unit been in for years playing fine ?
Unit has been in for years , now screen says disconnected wire?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
If you can, try checking your wire connections. If they check out fine, try checking your fuses and wiring for power.
Posted on Apr 10, 2012
SOURCE:
I have a ken wood aftermarket headunit. I was always able to plug in my usb and play music through us now I hooked up my subs and when I pulled the headunit out I didn't disconnect any wires or anything...
You didn't give much detail on model of unit, etc. However I remember vaguely from my wife's KW DVD/Nav unit, that the USB port can serve one (and only one) of 2 purposes. One is as an "uplink" to firmware (I think, or maybe it was some sort of remote control, been too many years), the other is what you want, as an "accessory" USB port. It sounds like that setting might have gotten changed while doing your setup. Download the manual for your specific model number from Kenwood and it should have details there.
Dec 04, 2013 | Audio Players & Recorders
Model RTD325W My DVD player has been locking up during a movie and even when I am listening to just the radio (tuner mode) I am forced to unplug to reset since it will not allow me to power off with...
Fastest way to check this is to disconnect all speaker wires from the unit leaving the video hooked up and play a disc. If it keeps playing fine, you have a speaker or wire problem. If it still reacts the same, it's an internal problem and would need to be serviced. If the unit continues to play, post a reply and I will describe in detail how to troubleshoot the system. Hope this helps
Jan 24, 2011 | RCA Audio Players & Recorders
Please describe how to by pass the park brake wire when installing a kenwood dvd player model kvt715
the light green wire should be the one and you have to connect it to the earth then you can watch movies when u drive
Aug 12, 2010 | Car Audio & Video
Kenwood KTS-300MR
you need to firstly trace the speaker wires to the unit to make sure there connected first. if they are then its a job for a car audio expert ( if there is such a thing) if the unit is connected to correctly to the speakers then there is an internal fault ..
Jul 03, 2010 | Kenwood KTS-300MR CD Receiver
Well my epson projector fell and now the screen doesn't play it just shows the white screen but the audio works perfectly fine.
~ power on the unit and disconnect all sources (dvd,computer,etc) * if it shows "No Signal" and Blue screen, the unit is ok~ try using another cables
Jun 17, 2010 | Epson PowerLite® S4 LCD Projector
Dvd plays but it turn blue whit no pic
Yes, your parking brake safety wire has been run the correct way, so it will only play when you are in park. If that is the case, you must disconnect the pink parking brake wire from the parking brake ground, and connect it to the radio units main ground wire. This will tell it that it is always in park. Caution, they put the wire there for a reason, very distracting to have a movie playing in the front seat.
May 17, 2010 | Dual XDVD8180 Car Video Player
Video won't play
I am not sure about that brand but you are relly supposed to connect the wire coming out of the back of the screen that says "parking brake wire" to the cars parking brake wire or it can by green, black , or several other colors depending on the manufactor. If you do not do that and you just connect that wire to the ground wire "the black one" and it does not work the the screen most likely needs to have some sort of reaction to happen. try turning the unit on then grounding the black wire (the one coming from the unit that should be connected to the vehicles parking break wire) . You may have to install a switch if this works. If you still have the manual look and see if it tells you if the is a sequence like turn on the unti then apply the parking brake release it then reapply and this will tell you how to wire up the switch.
Apr 23, 2009 | Car Audio & Video
I have sound but just a black screen
Hello lolly, What i would suggest is disconnecting the wires and examining them. Examine the prongs and if any are shorter or missing then that would be your problem. If therething looks fine then it would be your xbox which will need to be sent back.
Sorry to inform you, but i hope this helps.
Nov 16, 2008 | Microsoft Xbox 360 Console
Kenwood DNX7100
or the parking prake wire is not grounded... that's what happened to me. Just find a spot to ground the parking brake wire and video should appear.
Feb 15, 2008 | Kenwood DNX7100 Car Video Player
No sound from anything but FM
Disconnect whatever's connected to the blue wire behind the unit, and re-connect it to the blue/white wire instead.
Aug 05, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-715DVD Car DVD Player Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
