Astra Meridian 9417 Corded Phone Logo
Posted on Nov 11, 2008
Message waiting indicator light will not turn off keeps flashing
is there a manual reset?
  • Anonymous Dec 15, 2008
    I have the ooposite problem the LIGHT that indicates their is a message for me does NOT turn on THANKS
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
6617
Points
11
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
  • matt wilkie
    matt wilkie Jan 15, 2015
    thank you so much! this has been bugging me for years and nobody I talked to had a clue what to do.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6150
Points
On Vista 200, slide the Grey Bar (slides to the right)
Press the exposed Options/Setup button
Use down arrow button to go to Turn Light Off option
Press 4 to turn it off - Display should indicate "confirmed"
Slide grey bar back into place...the light should be off
Test it by picking up an extension phone to make sure the light comes on as per normal
My Vista 200 says Message waiting. How do I retrieve it?
https://www3.bellmts.ca/mts/support/phone+services/troubleshooting/you+have+no+new+messages+waiting+but+your+phone+says+you+do
Turn off Message Waiting Notification temporarily
  1. If you know you have a message waiting, but do not wish to retrieve it immediately, you can turn off Message Waiting Indicators.
  2. Press *93 to turn off the flashing light and stuttered dial tone until another message is received in your mailbox.
Voicemail light keeps coming on
From att.com:
Q: What should I do if I my Message Waiting Indicator, stutter dial tone or light on my phone, is on but I have no new voice messages?
A: Make sure to check all message types when reviewing your messages (i.e. voice, email and fax).
Q: What should I do if my Message Waiting Indicator (MWI), stutter dial tone or light, is stuck on?
A: Power cycle (turn off/on) the Phone or Customer Premise Equipment (CPE).
31helpful
I have a uniden dect1580 6.0 and the red light in the left hand corner blinks all the time.
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
A beep sounds and the message alert tone is reset.
4helpful
Have no message but red light keeps flashing
The term we used for this back when I worked for the phone company was a "stuck message waiting indicator" and the way to fix it was:
Call yourself and leave a message.
Hang up and wait 2 minutes (we used to say 5 minutes, but 2 is plenty)
Retreive/delete your voice mail message
That should clear the blinking light.
26helpful
CD445 voice message icon won't stop flashing
This feature is country dependent and may not
appear in some countries.
If you have subscribed to the voicemail service
from your local service provider, icon turns
on when you have a new message in your
mailbox. After you have accessed to all the new
messages, icon will turn off automatically. If
you find that the message waiting indication
cannot be turned off by the network, you can
still turn off the message waiting indication with
your phone by the following step :
In idle mode, if voice mail waiting icon is on,
long press the redial key to turn off the voice mail waiting
icon.
Once you choose to delete the message waiting
indication, all the other handsets registered to
the same base station will turn off the message
waiting indication accordingly.
3helpful
3answers
1helpful
Msg button flashing
go to the phone where the light is flashing press intercom #409. you may have to do that more than once. Keep doing it until the light goes out.
If the phone system is a DK 8 orDk16 press intercom 409 this will cancel the message waiting light that could have been cativated by a different extension.
1helpful
Red message light flashing
1helpful
Tmc4000 voicemail light no longer flashing when messages are waiting
First of all here is a link to the manual for you ...enjoy !
http://www.sellcom.com/ET4000%20users%20guide%20%20v7%20090803.pdf
On page 72 there are instructions for re-setting all programmed features to default, then you can start afresh...good luck
22helpful
Try holding the mute/find handset button on the base unit for about 5 seconds and the light should stop flashing.
Top Astra Lands Phones Experts
k24674
Are you an Astra Lands Phone Expert? Answer questions, earn points and help others
