Question about Toshiba 32AF42 32" TV
The remote doesn't work on my toshiba tv zp38
The remote don't work anymore. I've tried recoding them and fresh batteries but no luck
    Top Expert:
  • Toshiba Master
  • 76,060 Answers
Check the infrared emission from the remote control first. If it is found OK, repalce the infrared sensor inside your tV.
To get more details about how to check the remote control, get into this blog.
'electronicshelponline[dot]blogspot[dot]com
Named 'Electro-Help'
Posted on Apr 10, 2012
SOURCE:
  • 1694 Answers
SOURCE: tv sensor for remote doesnt work
1) solder bad connects on remote sensor mounted to front edge of circuit board or, if necessary
2) Replace sensor Tosh # 23009490 ...........................T.
Posted on Jan 08, 2008
  • 18 Answers
SOURCE: Toshiba 28N33B
If micro and eeprom have changed and still faulty, the your problem might be the infrared receiver ggod luck.
Posted on Jan 31, 2008
bernardlunda
  • 318 Answers
SOURCE: The hand held remote will not work for my toshiba
its batter in a shop were spares can be found. in side a tv there is a photo senser which converts light into electrical signals.
let the photo diode be tested
and also the remote you have on other toshiba sets to confirm, if remotes are a problem or not.
remotes have codes to change to another remote, 060, 019, 014, 052, 059, 075.
Posted on Apr 01, 2009
  • 32 Answers
SOURCE: Remote was not working well, called Toshiba.
check out if the infrared is emited from your remote control, if it is NOT, then there could be problem with your infrared receiver embedded in the tv set.
to see this infrared beam, you need to read the article posted at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Posted on Mar 14, 2010
  • 130 Answers
SOURCE: Toshiba 32A43 - suddenly stopped
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
Posted on Sep 28, 2010
Remote Control won't start TV
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jun 14, 2017 | Toshiba 22AV500U 22 in. LCD TV
I 've lost the remote control for our toshiba super c3 tv, can I buy another Toshiba control ?
Try the toshiba site or Google the model number with "remote" to try to locate an original not a universal.....
Nov 05, 2012 | Televison & Video
Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Toshiba Televison & Video
My panasonic tv remote won't work, the tv will work from the buttons on the actual set but the remote doesn't
The remote might be defective. Repalce fresh batteries and check. If it do not help you, buy an other remote
Mar 31, 2012 | Panasonic Televison & Video
One day the remote stopped working. We changed the batteries to no avail. The led lights on both the TV and remote do not light on anymore. The TV turns on/off using the power button and I can also use the...
Jul 13, 2017 | Insignia NS-27RTV 27" TV
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
Jul 02, 2011 | Televison & Video
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
I'm trying to connect my Wii console to an old magnavox tv my aunt gave me. I don't know how to connect it because it doesn't have the tv/video button on it. I've tried reconnecting...
U have the tv original remote?Look for a button said Input,used that button push it to goes into video mode 1 or 2.Don't have the tv original reomote.Try website like Remotes.com to buy the tv original remote.
May 08, 2011 | Televison & Video
The remote for my 20: LCD TV has stopped working, i have changed out the batteries and even bought a new one but still nothing. What should i do?
there are several things to try.. first, isolate the source of the problem... get a universal remote (borrow one from a friend if you don't have one--get the instructions, too)...then program it for your tv...if the UR doesn't work, then there is a problem with either the tv or its remote sensor...try the troubleshooting guide for the tv or call the customer service line (ask if there are similar probs going around for that model..you might get some special incentive to quit ****, if so..) If it DOES work, then it's your remote...best thing to do is make sure that the batts are good (which you did....but make sure you didn't get a fresh set of batteries from the same bad lot - it happens)...then check to make sure that the connections for the batteries are not missing, broken, or bent.. Look for corrosion, loose wires, solder gone...anything you can see which might cause your problem...Nothing visible? send it back..or try to exchange it at the store you bought it from, if it's a currently selling model Hope that helps you
Feb 22, 2010 | Televison & Video
Toshiba 32AF42 32" TV Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
