Yes! it could be, is the window 7 a upgrade disc? the reason I ask it will detect the previous version and install, but if the hard drive has been completely formatted it won't install on empty hardware. If that is not the issue go into bios and reset to factory default it might make the difference.
SOURCE: bios update
You can try and change the boot device by pressing on F12 on POST. The computer will prompt you to select a boot device after pressing on F12 on power on.
SOURCE: Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
SOURCE: IBM Lenovo t60, the logon user interface DLL
To wipe and reload you don't actually have to log in. You just need to set first boot option to CD, insert the XP disk, and reboot the computer. All the steps from there on out are explained on the screen.
I hope this helps :)
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
