SOURCE: Wrong Power Adapter
Yes.If the voltage range exceeds the limit,"astalavista baby."
If the voltage is was below recommended,try plugging in Power Only,turn on,leave for a minutes.This should adjust the voltage regulator back to normal.
SOURCE: Fried HD?
Yep, it's probably fried, a little too much juice went in.
While the drive itself might be ok, the external casing is another story.
Try opening the case and removing the HD and plugging that in on your PC directly as a slave drive.
SOURCE: mistakenly plugged maxtor one touch 2 into wrong power adapter
Well Most Likely The Circuit Board Burnet Out Since Its 12V And When Plugged Into A 19V Supply It Will Burn Out Instantly Because It Over Charges The Circuits. So Its Not Possible To Repair Such Damage But You Can Take Out The Hard Drive And Plug IT Into A Desktop Computer And Use It At Home Or As An Online Hard Drive To Store Files
SOURCE: iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
SOURCE: I lost the power supply for my WD2500 external HD.
My Book Essentials
12 Volts
3.0 Amps
36 Watts
Sometimes WD will even send you a replacement free of charge, if you give them a call.
