I get this error when trying to save .sig file as a PDF. This is with windows7
SOURCE: Can't open .pdf file email attachments from Windows Mail (Vista)
Send yourself another known working PDF attachment and see if the same thing happens. If it does, post back. If not, then it most likely means there's either a naming issue with the problem PDF, or it is just corrupt enough to give you troubles when opening from email.
SOURCE: I WANT TO CREATE A DATABASE FOR PDF FILES USING MICROSOFT ACCESS
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
SOURCE: cant open pdf files. adobe not working
If you are using Win7, and you install Acrobat 8.0 on the system. Due to software compatibility the software is not going to work.
SOURCE: Since installing the latest version of adobe
De-install Adobe reader & re-install - some problem occurred during download or installation.
To de-install (under Windows XP):
START > Control Panel > Add or Remove Programs or Windows Components > highlight
"Adobe Reader X" > L-click "Remove" (button)
Download & install Adobe Reader per the manufacturer's instructions.
SOURCE: Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
Getting the erdmpg-6.dll error pretty much indicates there is something wrong with the erdmpg-6.dll file, either it is absent from the computer or is damaged (corrupted), if so, the system will unable to read or access to the file when needed. When you encounter the error, first reboot your computer once, if the error persist, you can try to download the erdmpg-6.dll file from the internet, or get a healthy copy from another computer, and then replace the file in the suitable area in the computer.
Secondly, you can try to reinstall the program/application that trigger the error tofix erdmpg-6.dll error. but remember not to reinstall it until you uninstall the current installed one, to uninstall a program, go to Start > Control Panel, click onAdd/Remove program option and use it to do the removal.
Most of the time, registry problem is responsible to the erdmpg-6.dll error. Windows registry is part of the system, it is much important than any other system components, all the software & hardware data are stored in the registry. The erdmpg-6.dll error usually happen when the Windows registry gone corrupted or the related entries inside is damaged. To test if the registry of your computer is having problems, you can perform the steps below:
If you are experienced enough, you can open the registry editor, find out all the unnecessary or wasted entries inside, and delete them all, then modify the problematic key value to the proper status. Before any modification, we suggest you to backup the registry first to avoid crucial problems caused by mistaken operation.
Registry modification is kind of a complicated task for average computer users since there are thousands of registry entries, it is hard to spot out and clean every wasted one, no mention to modify the incorrect entry value, it can be dangerous if the value is modified improperly, your computer may end up crash, even registry backup can't save it. Fortunately you can use registry tool to help you out, simply follow the below three steps, you will be able to fix the registry as well as fix erdmpg-6.dll error automatically:
Step1: Free download erdmpg-6.dll error fix tool, and then install it in your computer.
Step2: Click Start Scan Now button to scan over your computer for existing problems and errors.
Step3: Click Fix All button to completely fix erdmpg-6.dll error.
Open your computer's Internet browser.
Type www.a-pdf.com/security/a-pdf-rr.exe in the browser's URL box to access the PDF restriction converter "A-PDF Restrictions Remover."
Press the "Enter" or "Return" key. Your Internet browser will access the site's PDF converter file. A dialog box will appear on your screen--"Opening a-pdf-rr.exe."
Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer for running later--use this option if you using a slow connection like dial-up. The program will download and set up on your computer if you selected the "Open" or "Run" option.
If saving the file to your computer, navigate to the directory where you want to save the file to. Select the "Desktop" if you have a hard time locating downloaded files on your system.
You do not have to access the A-PDF Restrictions Remover website again once the file starts downloading or saving to your computer.
Double click on the "a-pdf-rr.exe" icon to open the program, if you selected the "Save" or "Save As" option.
Click "Run" when prompted with the "Open File -- Security Warning."
Click "Next." Click on the circle by the wording "I accept the agreement." Click "Next."
Select the directory where you want to save the "A-PDF Restrictions Remover" file. The default is your "C:\Program Files\A-PDF Restrictions Remover" folder. Click "Next."
Click "Next," "Install" and then "Finish." A-PDF Restrictions Remover will start automatically.
Navigate to the directory where the protected PDF file is located.
Right-click on the PDF file name. Select "Remove Restrict & Save As."
Select a location to save the converted PDF file to. Click "Save." If you want to change the PDF file's name, enter a new name in the box next to the wording "File name." The protected PDF is now converted to a unprotected one.
Double-click on the converted file to open it.
Select "File," "Print" and then "OK" to print the unprotected, converted PDF file.
Open the protected PDF file2
Press the "Alt" and "PrtScrn" keys together. The PrtScrn key is located on the upper right-hand side of your keyboard, if using a desktop computer keyboard. If using a laptop, the PrtScrn key is located above the "F10" function key.
Open your computer's word processing program by clicking on the program's icon on your system's "Desktop" or from the "All Programs" menu.
Press "CTRL" and "V" keys together to paste the screenshot into a blank document.
If using a Mac, click "Edit," "Paste" from the main toolbar at the top of your word processing program.
Click "File," "Print" and then "OK" to print the PDF screenshot. If the protected PDF file contains more than one page, press the "PgDn" key and repeat steps 2 through 5.
