Unsure how to lift the top of the printer to change the ink cartridge
With the machine powered on. Just lift up on the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
Open the machine in the middle front (pull up) the ink cartridges will move to the middle (must be turned on). The ink that needs replacing will be blinking. lift up on the front lip of that color,it will come out, just put another in the slot and press it until it clicks in. The light will no longer be blinking for that one. If more than one is blinking,change all that are blinking.with the proper replacement color. close the machine and answer yes to changing the ink question. you are done. Hope this helps.
after i changed the ink cartridges the printer would not power up
