I have erased previous announcement. The button choices are on-off, change, announc. What sequence do I use to record new announcement? Thanks. (There is a mini tape in the compartment.)
Recording the Outgoing Announcement
For best results when recording, you should be about nine inches from the microphone,
and eliminate as much background noise as possible.
1. Make sure the answering system is On2. Press and hold the announce button on the base.
3. Begin speaking after you hear the beep.
4. Release the button when you finish your announcement.
NOTE: If you choose not to record an outgoing announcement, a default
announcement plays instead. To return to the default announcement after
you have recorded your own outgoing announcement, press the announce
button and release it when you hear the beep.
Sample Outgoing Announcement
"Hi, this is (use your name here), I can't answer the phone right now, so
please leave your name, number and a brief message after the tone, and
I'll get back to you. Th anks.
To erase a message while it is playing, press the ON/OFF ERASE button. The
answering system announces, "Message Erased" to confirm the message has been
erased.
To Erase All Messages: When the answering system isn't playing or recording messages, press and hold
the ERASE button until you hear the "Messages Erased" announcement. Release the
button after the announcement. This feature allows you to erase all old messages
but not new messages. If you do not have any messages, the answering system
announces, "Zero Messages."
User Manual: http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
