My samsung yp-u5 4gb mp3 - player doesnt even get regonised with my computer it just says charging and i cant load up the folder to put more music on.
SOURCE: Samsung YP-Z5AB/ELS mp3 player problem
...Samsung returned my player after 3 weeks. Some problems fixed, but not all. Their customer service & tech support lines are hopeless, and eventually suggested I return the unit to Amazon ! Amazon have agreed a refund & Samsung have lost a customer permanently. It's a shame because this could be a great player if the internals were up to the mark.
SOURCE: Samsung Yp-T10 mp3
hi!~ I need you help.
I connected my mp3 to computer,
and opened the mp3 folder on computer,
and i'm supposed to see the system folder right?
but I couldn't find one for mine.
how do you create system folder on Samsung yp-t10?
that my problem too....
SOURCE: I have a connecting question for the Samsung P2
use control panel, then "add hardware" look for P2 in the list, reinstall it.
SOURCE: Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
