Cant find my songs on the player it only shows that i have one song but there are over 100 on it.
If you can't find your downloaded music, it means music is lost or damaged. In this case, you have to re-download music one more time. To make sure the successful downloading process, here you can use Leawo Music Recorder to record music from any online sources. You can follow steps below to download music online:
Step 1: Download and install Leawo Music Recorder on your computer
Step 2: Launch the software and open source music.
Step 3: Hit the red button on the top right corner. At the same time, play the source music.
Step 4: Click the red button one more time to stop recording. By default, you will find recordings with this path: This PC > Music > Leawo > Leawo Music Recorder
MP3 players can only play music files in mp3 file format.1st - You need to convert your CDs to mp3 music filesonto your computer or download them from the Internet and then copy them toyour MP3 player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
There are also Freeware CD RIP programs on the Internet that add the musictitle and album title to the mp3 file automatically.
OR
Download mp3 music files from the Internet to your computer, some sites willcost money to download these music files.
2nd - connect your MP3 player to your computer using the supplied USB cable.The computer will see this player as an external storage device, Just copy theMP3 music files from the computer's hard disk to the MP3 player.I suggest you create a album/title folder for each CD soyou can place the mp3 music files by that artist into that folder. Then copythese folders to your MP3 player and you will be able to select and play yourMP3 music by selecting the album you wish to play.
NOTE - When the USB cable is connected to the computer, it will also charge theMP3 player's battery.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
SOURCE: My Coby MP-705 Won't Let Me Delete Songs
Make sure your player is not active. Unplug it from your computer and turn it off. Now plug into your computer. Go to the start menu on your computer and select "run". Type in the port your unit is plugged into or use the dropdown and select. This should display your 705 contents. Highlight the file you want to delete, then right click and select delete. Hope this helps.
SOURCE: Won't play music I copied-Coby c-582
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
I'd like you to try something so that we can see if there is something wrong with your player. First, I'd like you to format your player. This will wipe it clean of any files that are on it. To format, follow these steps:
Step 1
Connect the unit to your computer via the USB port.
Step 2
Double-click the My Computer icon on your desktop, or, click your start button and choose My computer from the right side of the start menu.
Step 3
Right-click the icon for the Coby player.
Step 4
Choose Format from the menu that appears, and choose quick format after that.
Step 5
You'll see a warning that formatting will erase all data on the drive. Click OK.
After this has been done, go to the MY MUSIC folder that is found by clicking MY DOCUMENTS on the start menu. Open the folder labeled sample music and copy and paste one of those songs into the player. Then disconnect the player and see if that one song will play.
If you're able to load a sample song as described above and it doesn't play on the player, unfortunately this would mean the unit is defective and needs to be replaced. It can not be fixed. The warranty is 90 days from the date of purchase. You will need a receipt for warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
SOURCE: how do i delete multiply copies of the same song?
Did you try to go from the Main Menu into the EXPLORER ?
Explorer Controls
When you choose EXPLORER mode from the Main
menu, you will see the File Explorer screen. You can
find and delete files or folders from the player.
Function Key Action
To browse through the list of
files & folders
Press <UP> or
<DOWN>
To select a folder Press <ENTER>
To return to the previous screen Press <LEFT>
To delete a selected item Press <MENU>
To return to the Main menu Hold <MENU>
the music was already there and playing, now all of a sudden it only shows me as having 1 song when i had 104 on there.
