I purchased a dell insiron b120 from a friend but it won't let me in without a admin password. it won't let me go into the bios, startup screen, or advanced startup. is there a way to bypass the admin password or reset it?
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b120-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
You need to go back to your friend and get the password, or have the money refunded if the information can not be provided. You can't bypass or reset, go to www.ebay.com Type: administration password you will be presented with a list of sellers, go with the one that handle's Dell this will increase the chance of success.
SOURCE: how do you reset the cmos bios admin password on the dell 1200
Here's a good reference site. Click Here
SOURCE: Lost Admin or system password for Dell Vostro 1700.
First off is there two passwords one for bios one for gaining access to the O/s ?
If its a system startup password basically you need to take the battery out for a minute and replace ( Easier to do on desktops )
or Flash the bios can't promise that would work or be easy on a laptop either. Would have to google that.
SOURCE: Dell D505 BIOS Reset
Generally, all you need to do is get on to Dell Support and get in a chat with one of their people and tell them that you are locked out by a BIOS password, and needed to get around it. After they verify that you are the owner of the laptop, they should give you a password that gets you through it.
SOURCE: Shut down problems on my Inspiron 1525
I have the same problem. Never buying a dell again. I found this thread with a solution that seemed to solve the problem for most people:
http://social.technet.microsoft.com/Forums/en-US/itprovistasp/thread/e18685ed-d211-41f6-8c68-b242aeabf002
Hope it works for you too!
SOURCE: Dell inspiron 1300 bios password
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
