Where do i find the factory code or get the default so can open it and reset
SOURCE: Father has lost safe combination to Sentry 1250.
try looking under the thesafe see if it has a reset button or u could read the sticker(if there is one) and see if u could get the store that u bought it from, to reset the combo
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
SOURCE: Sentry safe default admin code
I hope you registered you safe after you bought it. If not you
still have a chance. Contact their support here.
Cheers
TeaCii
If
you own website, add live support almost free
Real
security guard to watch your cctv for $1/day
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe.
First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784
If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
