Only one speaker output works
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
SOURCE: help with my power amplifier
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
SOURCE: Are you able to provide a circuit diagram or even
I am sure I have fixed this model in the past. A lot of Rotel gear of this vintage, although sounding quite good, had been farmed out to Taiwan for manufacture. This was back in the day before electronics came from China. But the quality of the build was often low grade, and hand assembled with custom made IC's and transistor arrays that are no longer available due to local manufacture(taiwan). Some gear was Japanese and better build quality. Look for a 5 legged transistor (small black bodied device) device, or blackening of the legs of any transistors(black death i call it).Is it possible to post an in focus picture pof the internals to jog my memory on this amp.
SOURCE: the two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
